How do I adjust the low beam height on a Peugeot 207? It's too high and keeps blinding other drivers at night.
How can I adjust the high and low beam headlights inside the car?
Can the low beam headlights of the 2010 Peugeot 207 be adjusted for height?
4How to adjust the low beam height on the GAC Trumpchi GS7?
5How can I adjust the headlights to aim higher? The low beams are too low on my 2018 1.8T model.
6Does anyone know why the high beam and low beam headlights keep breaking?
7How can I adjust the low beam height on my H7? They're too low. Also, how do I use the headlight cleaning system? Waiting for some advice from fellow car enthusiasts. 🙏
8How do I adjust the low beam height on the Hongqi H7? It's too low. Also, how do I use the headlight washer? Waiting online for help from fellow car enthusiasts. 🙏
9I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
10For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
