أحمد مدرسي
2023-09-20 23:07
Hey guys, how do you reset the trip meter above the total mileage on the dashboard? I have a 2011 base model, manual transmission, 1.4L hatchback.
وهاب علي
وهاب علي2023-11-10 06:45
Hold the right stick down and it'll work.
عبدالرحمن زكريا
عبدالرحمن زكريا2023-09-21 01:40
There are two black sticks on the dashboard. Try pressing and holding one of them.
To reset the trip meter A on a Haima S5, it's usually done with a small button on the instrument panel. If you can't find it, refer to the owner's manual for specific instructions, as the button might be less visible or located differently.
I recently got an 08 Mazda 2 hatchback, 1.3L automatic. It has been driven 130,000 km over 15 years. I've been driving it for about 10 days, mostly commuting in the city with a round trip of 40 km a day, but the fuel consumption is ridiculously high... After the fuel warning light first came on, I added fuel worth 200 yuan, which was 25.6 liters, and drove a total of 247 km. The average fuel consumption was 10.35 liters/km, costing 0.8 yuan/km. After the fuel warning light, the engine light turned yellow as well, what's going on??? I didn't think too much and just drove to the gas station, asked the staff to fill it up, but it could only take 34 liters before the pump stopped. The staff said it was full. Isn't the Mazda 2's fuel tank capacity supposed to be 43 liters? Why is it full so much earlier, is there something wrong? Looking for help, how should I deal with this? Has anyone experienced the same situation?
How do I reset the trip meter after maintenance on a V40?
If you're considering the Jetour X70, there are a few things to keep in mind. Here are some pros and cons based on general feedback: Pros: 1. **Design**: The Jetour X70 is often praised for its stylish design and aesthetic appeal, which seems to be one of the reasons you're considering it. 2. **Space**: It typically offers a spacious interior, making it comfortable for families and long trips. 3. **Features**: The vehicle usually comes equipped with a range of features that enhance comfort and convenience. Cons: 1. **Manual Transmission**: If you're looking at the manual version, consider whether you prefer this over an automatic, especially in heavy traffic conditions. 2. **Brand Recognition**: Jetour might not be as well-known as some other brands, which could affect resale value and brand trust. 3. **Performance**: Depending on your expectations, the performance in terms of horsepower and Fuel economy might not match some competitors. Overall, it's important to weigh these aspects based on your personal needs and preferences. If possible, test driving both the Jetour X70 and Jetour Dasheng could help you make a more informed decision.
How do I reset the trip meter on a 2016 V60CC? I watched a video yesterday that said to press the "O" button on the steering wheel control, and it worked yesterday. But today, it doesn't respond. Any advice?
After replacing the battery on a 2017 Skoda Octavia 1.6 manual with low trim, the trip mileage, average fuel consumption, and other information on the dashboard reset to zero every time I lock the car for about 2 hours and then start it again. Has anyone encountered this issue or knows how to fix it? Please let me know. Thanks.
