Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
Is it normal for the clutch of a 2009 Accent to have some play at the beginning when you press it?
When I press the clutch, there's a squeaking noise, but it goes away when I release it. Is there a problem?
I want to ask about my 2019 Changan Yuexiang automatic. When I start the car cold and shift gears, it takes about 2000 RPM to change gears, like the clutch is slipping. Once the engine warms up, the shifting is normal. Do other car owners experience the same issue?
4Why can't the Pajero burn out when the brake is fully pressed and the accelerator is fully pressed in D gear, with the RPM only reaching a bit over 2000?
5Hello everyone, could someone help me with this issue? When in Park and idling, if I rev the engine above 1600 RPM and then release the throttle, the RPM stays around 1600 for about ten seconds before it drops. This doesn't happen if I don't exceed 1600 RPM. Between 1600 and 2000 RPM, there's a noticeable jolt. Additionally, when shifting gears and slowly accelerating, there's a rattling noise between 1600 and 2000 RPM, but it disappears after 2000 RPM. Does anyone have any insights on this? I would really appreciate it. The car model is a 2016 30T two-wheel drive. Thank you very much!
6When driving a manual transmission car, if you hear a rubbing noise from the engine slightly above 2000 RPM, but it disappears above 2300 RPM, what could be the reason?
7What could be the reason for a vehicle with an 8-speed automatic transmission to jerk when shifting from 3rd to 2nd gear?
8Hey everyone, I've been experiencing some jerking when I press the clutch on my car. What could be the reason for this? It happens when I try to shift gears at 2000 RPM.
9Hi everyone, I have a 2013 Suzuki Alto automatic. When I start and just slightly press the accelerator, the RPM quickly goes up to 2000. Even when the speed reaches 60, the RPM stays around 2000. What's going on here?
10When lightly pressing the accelerator at low speeds, there's a slight jerk, and when the RPM drops below around 1100, there's a dragging feeling. What could be the problem?
