حسين عبد عزيز
2024-01-06 08:59
Here’s the situation: I just replaced the battery, but it's dead again. After starting the car, after a while, it reports a battery charging fault. Then the ABS and airbag lights also come on. When idling in place, after a while, the car will automatically shut off. When driving, it feels like it doesn't shift gears automatically, and I can't switch to manual mode either. Vehicle: Peugeot 207 1.6 Automatic. The battery wasn't great initially, and I didn't pay much attention to it, usually jump-starting the car. A few days ago, I replaced the battery. First, during driving, it started showing a battery charging fault. After a while, the ABS light came on, then the airbag light lit up as well. It's like a parade of warning lights. Now I'm wondering if it's worth repairing. What could be the issues?
عبد العزيز أم
عبد العزيز أم2024-01-09 11:19
Battery voltage
أم سلمان
أم سلمان2024-01-06 20:20
Try resetting the code after replacing the battery.
After the vehicle inspection, a series of warning lights for ABS, ESC, electronic parking brake, and hill-start assist light up. Usually, they don't light up when I start driving, but after a while, they do. I went to the repair shop to clear the fault codes once, but after driving 20 to 30 kilometers, they came on again. Does anyone know what the cause might be?
What should I do if there's an airbag fault in my Touareg?
Does the alternator occasionally not charge and cause a fault alarm? Should it be replaced?
Changan Alsvin, ABS and anti-skid faults, diagnostic shows left front wheel speed sensor fault. I replaced it, but the lights are still on. The diagnostic still shows left front wheel speed sensor fault, but all the data streams are there. The fault can be cleared, but it comes back while driving. What should I do?
Changan Yuexiang, ABS and anti-skid fault, diagnostic shows a left front wheel speed sensor fault. I replaced it, but the lights are still on, and the diagnostic still shows the left front wheel speed sensor fault. However, all the data streams are present. The fault can be cleared, but it comes back while driving. What should I do?
Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
The engine won't start, and the EPC, battery, and engine fault lights on the dashboard are all on. What could be the reason?
The charging station's fault light is flashing, and it cannot charge normally.
