Does anyone have a solution for the clutch spring getting stuck on my foot? Any suggestions, folks?
Has anyone experienced the central control display screen constantly restarting? My 2017 Multivan started having this issue after changing the battery. Any good solutions?
How do you charge your phone? The cigarette lighter USB can't charge my iPhone, but it works with OPPO. Does anyone have any solutions?
Hey folks, have any of you experienced clutch master cylinder oil leaks? It seems like the leak is at the connection between the master cylinder and the oil pipe. Is this a common issue?
4Hey folks, has anyone modified the foot brake parking? I'm thinking of making some changes.
5Looking for suggestions on choosing AT tires. I have a 2014 model and want to switch to AT tires. Any recommendations from experienced folks? Thanks! 🙏
6For manual transmission, has anyone experienced the issue of the clutch not returning? How did you solve it? Should I replace the slave cylinder or the spring?
7This car is overall okay, but the manual transmission clutch isn't very user-friendly. I bought my car in 2020, and it's run 23,000 kilometers. In the city, where the clutch is used frequently, it gets harder the more I press it. Do any of you guys have this issue?
8Does anyone have a solution for the clutch spring getting stuck on my foot? Any suggestions, folks?
9I've noticed that the two air vents under the main driver's seat in my ASX tend to blow cold air on the left foot. Not sure if other drivers have experienced the same issue. I tried blocking it with tissue paper, and it seems to help a bit. Any other good solutions from fellow drivers?
10I experienced a similar issue with my steering column making noise and feeling stuck. The dealership suggested replacing it, but it's quite expensive, so I didn't go for it. How did you guys deal with this problem? Do you have any good solutions? My car is over three years old and has run more than 20,000 kilometers, and this issue has come up. I think there might be a quality issue here.
