علي جليل
2023-10-31 20:37
At what temperature does the cooling fan of the Peugeot 207 start working?
عبدالرحمن ق
عبدالرحمن ق2023-11-18 12:49
100 is high speed, 90 is low speed.
When driving, if the electronic fan does not start at high speed after turning on the air conditioning and the water temperature is high, how can this be resolved?
Hey guys, where is the exterior sensor on a Peugeot 207?
What could cause a Peugeot 207 to sway from side to side while driving normally?
What's up with the 2009 Peugeot 207's multi-function display showing dashes for temperature? Does this car not have a temperature sensor?
Where is the front tow hook located on the Peugeot 207 sedan?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
What could be the reasons for the Peugeot 3008's automatic start-stop function not working properly?
