عبد العزيز شجاع
2024-01-29 00:16
Any experts can tell me how to change the right low beam light? The right one isn't working, and I really can't get my hands in there. I've got the light but can't install it.
فهد رامي
فهد رامي2024-01-29 15:42
You can change it. I did it myself too.
I just got a 2018 Roewe RX5 1.5L automatic deluxe edition. Is it normal that when I turn on the high beam and push the light lever back, it doesn't switch to the low beam? Could something be broken?
Hi everyone, I need some advice. I bought a second-hand 2017 F150 XLT model, not sure from which country. Here's the issue: No matter what the setting is, when I shift gears, the low beam lights turn on. If I turn off all the lights, the daytime running lights don't come on, but when I shift gears, the low beam lights turn on. When the automatic headlight setting is on, the daytime running lights come on, and in park mode, the low beam lights don't turn on, but after shifting gears, they do. I'm wondering what could be causing this and if there's a solution?
Can I replace the low beam bulb on a 2010 S40 myself if one is not working?
Suzuki Liana 2013 model! Why do all the lights work except the low beam? Where is the low beam fuse located...
Hi everyone! Could anyone tell me where the low beam fuse is for a 2013 Liana? All the lights work fine except for the low beam. Does anyone know what the issue might be...?
Where are his low beam lights?🧐
Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
