أحمد إدريسي
2023-10-02 01:34
Peugeot 206 automatic. Exhaust pipe leaking oil and emitting white smoke. The car can move on flat roads but the engine shakes. It lacks power going uphill. What's going on?
علي بوتفليقة
علي بوتفليقة2023-10-06 09:06
Is there an issue with the ignition coil?
خالد خير الدين
خالد خير الدين2023-10-02 11:40
Go to the repair shop. Isn't white smoke just coolant entering the cylinder?
I parked my Territory in the mall's underground parking. After paying the parking fee and stepping on the gas to go up, it suddenly couldn't move. The car started shaking like "tut tut tut," and it felt like something was stuck in the front. The engine seemed to lack power.
Pajero V93 chassis is leaking oil, and it's dripping onto the exhaust pipe. It needs repair.
Dear car enthusiasts, has anyone added a catalytic converter cleaner to the fuel tank of a 2011 manual Touran? After I added this kind of cleaner, it started emitting white smoke and the check engine light came on. Has anyone experienced this situation?
14 model, 1.5T, exhaust pipe doesn't emit blue smoke, but there's significant oil consumption. Can any expert shed some light on this?
I used to drive a Ford Focus, and now I'm driving an Outlander. The Outlander is smooth on flat roads, but there's a noticeable lag when accelerating. The Focus would respond immediately when I stepped on the gas, and the steering was precise. The Outlander's steering feels a bit heavy, and when going uphill, it makes a lot of noise but doesn't move much. Even if I increase the throttle, the engine noise is quite loud.
Is the MG car lacking power when going uphill? Does it jerk in second gear? Is this common?
Help needed! I have a 2017 model 95. With summer here, there's white smoke coming out at startup, but it goes back to normal after a few seconds. There's no lack of oil or water, and the computer diagnostics show everything is fine. I've been to several repair shops, but no one has found the problem. Has anyone else encountered a similar issue?
This pipe seems to be leaking oil. Does this happen to you as well? Also, what is the purpose of this pipe? Is it for exhaust gas recirculation?
Is the lack of power when going uphill and the rise in RPM without an increase in speed in your fuel-powered Song Plus due to a spark plug issue? It's only driven 19,000 kilometers.
