عبدالله عيسى
2022-07-25 14:01
Peugeot 206, 1.6L, automatic/manual transmission, 2006 model. The acceleration is very slow, and when you give it more gas, the RPM goes up, but the speed doesn't catch up. What's going on? Can any experts help explain this? Thanks!
حسن تاج
حسن تاج2022-07-25 14:15
There might be an issue with the clutch; it seems to be slipping.
Hey folks, can the 1.6L Touran keep up in terms of power? What's the RPM at 120 km/h on the highway?
Hey guys, I have a question about the 2006 Peugeot 206 1.6 with the semi-automatic transmission. When I put it in reverse gear, the reverse lights don't come on. What could be the issue?
Hey guys, I want to ask if it's normal for my 2006 1.6 automatic Peugeot 206 to feel jerky when driving at 40 km/h and 60 km/h in D mode?
The temperature is around minus three degrees, and suddenly today the gear shifting is very slow. It used to shift at around 2000 RPM, but today it goes up to 3000 RPM. The engine is making a humming noise. 😵‍💫 Do any other T-Cross owners experience this situation?
Hey guys, my automatic Kia Sportage isn't moving when I shift into reverse. It only starts backing up when I give it some gas. Any ideas?
Car enthusiasts: Sometimes when driving a small car, the D gear won't shift up. The RPM suddenly goes up, but the gear doesn't match. What could be the reason?
Hello everyone, when I start my car cold, it makes a "dada" sound and the RPM goes up to over 1000, but it goes back to normal after about a minute. Is this normal?
Help needed, fellow Peugeot owners! Ever since my little Peugeot went on a continuous uphill drive for over an hour a few days ago, it's been having issues. The RPMs go up, but the speed doesn't. It's not too bad when not on the highway, as pressing the accelerator quickly gets the RPMs and speed up. But once I'm on the highway and going over 80-90 km/h, I need to press the gas to at least 2000 RPMs for the speed to increase very slowly. On inclines, if I don't reach 2500 RPMs, the speed drops. I never had to go over 2000 RPMs on the highway before. What's going on? 🌹
What's the RPM for your manual transmission car at 120 km/h? Mine goes straight up to 3400 RPM! [Shocked]
