أحمد رامي
2023-03-29 16:46
Is it worth buying a used Peugeot 206? Does it require a lot of maintenance?
Comments( 6 )
فهد مطلب
فهد مطلب2023-04-14 12:10
The 2008 manual Peugeot 206, apart from its fuel consumption, doesn't require much repair.
نايف خالد
نايف خالد2023-04-03 22:20
As long as it can be driven, just hold on and wait until it absolutely must be repaired. You'll find yourself on the road to repairs in the future.
عمر نور دين
عمر نور دين2023-04-01 21:44
So, it depends on what level of repair you need. Just need it to run, or want it to run well? For example, my fuel gauge isn't very accurate, but it doesn't affect usage at all (just remember when you refueled and roughly how long you've been driving; it'll still light up red if you're really low). But I couldn't tolerate it, so I got it fixed for 970.
عمر نور دين
عمر نور دين2023-03-31 11:21
Here's my experience with buying a car over the past year: - Purchase price: 13,800 - Film and color change: 2,400 1. 22/3/30, First equipment (chassis-related), 5,255. 2. 22/4/11, Second equipment (interior-related), 1,490. 3. 22/5/5, Third equipment, gear shift, 950. 4. 22/7/16, Replaced catalytic converter, 1,500. 5. 22/8/17, Tuhu: Tires 915, loudspeaker 2,379, headlights 1,299, navigation 1,499. 6. 23/1/30, Repaired fuel tank sensor, 970. All done at a Peugeot specialist shop. After all that, the car drives really well.
فهد حازم
فهد حازم2023-03-30 11:11
Not much, the entire chassis's wear-and-tear parts cost around 2k. The alternator belt and timing water pump are about 1k. Then it depends on your needs.
عبد العزيز بارزاني
عبد العزيز بارزاني2023-03-29 23:10
It was okay, the repair cost 4000.
