سعود إدريسي
2023-08-25 23:43
I just got a 206, and I've noticed that the body is lowered. Is it coilovers or lowering springs? I noticed the rear chassis is different from regular cars. Any advice?
عمر أشرف
عمر أشرف2023-10-22 17:41
For street driving, just go with shorter springs. For mountain roads and track days, if your budget allows, go for coilovers.
فهد مطلب
فهد مطلب2023-10-19 11:28
Priority short spring.
حسن وي
حسن وي2023-10-17 22:18
Torsion beam can be adjusted.
خالد أسد
خالد أسد2023-10-13 02:51
How much did you pay for it?
سعود بندك
سعود بندك2023-09-09 12:06
Prioritize coilovers.
Just got it home and looked in the garage, the front is lower on the left and higher on the right. Measured with a ruler, there's a 2 cm difference.
Hey everyone, should I replace the throttle body of my 206 with an aluminum one or a plastic one?
Hey folks, the car is uneven on one side, the driver's side is 3cm lower. I've replaced all the springs and shock absorbers, and also changed all the chassis bushings, but it's still the same. The driver's side leans heavily when turning. Can any experts offer some advice?
I want to ask, what's the difference between the sport suspension and the regular suspension on the Emira 2.0? If I chose the regular suspension, will it affect the vehicle's height?
My Kodiaq's rear inner tires are wearing unevenly and noticeably. The repair shop says the lower arm needs to be replaced because it's not an adjustable one, so four-wheel alignment can't be done. Does anyone know if this is correct?
My Kodiaq's rear tire is wearing unevenly, with noticeable wear on the inner side. The repair shop says I need to replace the lower arm because it can't be adjusted, and then do a four-wheel alignment. Is this the case?
For the 2017 BRZ, the lower trim and higher trim, specifically the S and RS versions, besides the difference in suspension, is there a difference in the central control? I noticed some websites show the RS version with a touchscreen central control while others show it with a basic single-disc radio central control.
I want to ask real car owners, besides the difference in power and the various driver assistance features, is there any difference in the chassis driving feel between the 2.0 and 3.0? I noticed the tires are different too, one is 255 and the other is 285.
