عمر رومي
2023-04-19 15:39
How do you turn on the high beam for the 206? The low beams can be turned on and the high beams can be activated by pulling the switch back, but it can't be pushed forward. What's going on?
حسن زايد
حسن زايد2023-05-08 21:20
The high and low beams on the 206 are controlled by a switch. In your case, it's likely that the switch is broken. Just buy a new one and replace it.
سعود مبارك
سعود مبارك2023-04-30 23:47
Raising the suspension didn't work for the front or rear.
عمر عاطف
عمر عاطف2023-04-26 21:51
Lift up for high beam, lift again for low beam.
سعود محملة
سعود محملة2023-04-22 16:49
Pulling it towards the driver switches between high and low beams. Pushing it forward doesn't work; this is a unique design feature of French cars compared to other brands.
سلمان قيس
سلمان قيس2023-04-20 19:28
Pull up, not push down.
Can the headlight assembly of the 2016 Kaiyi X3 be replaced with separate high and low beams?
How do I turn on the high beams?
How to turn on the high beam headlights?
How can I adjust the high and low beam headlights inside the car?
I recently replaced the headlight assembly on my Kia 2009 Sportage, and now I'm facing two issues: 1. The headlights can't switch between high and low beams. 2. The headlight level adjustment switch on the central control dashboard is not working; turning the switch doesn't affect the headlights.
Does anyone know why the high beam and low beam headlights keep breaking?
Who knows how to turn off adaptive high beams? I set it up and found that when I manually turn on the low beams, the dashboard indicator light goes off, and I still can't figure it out.
I've checked the high and low beam lights outside the car, and they can be turned on and off normally. However, when I switch to the high beams, the dashboard keeps showing a "high beam fault," whereas there is no fault reported for the low beams. Can any experts advise on what exactly might be the problem?
For a 2012 Kia Sportage with integrated headlights, if adjusting the low beam to the right position causes the high beam to point at the treetops, does anyone know how to solve this? How can the high beam be adjusted lower without moving the low beam?
