نايف مبارك
2022-11-30 21:44
Hey folks, my '09 1.4 manual has a really light steering wheel, and it keeps wobbling left and right over bumps. Also, there's a slight shake at idle. What's going on? [Crying]
عبدالله رامز
عبدالله رامز2023-01-19 09:20
There's an issue with the control arm. Or maybe the bolt connecting the knuckle and control arm is loose.
عمر ميرزا
عمر ميرزا2022-12-13 20:20
It should be an issue with your suspension.
علي له
علي له2022-12-01 19:55
Cleaning the throttle body
علي له
علي له2022-12-01 19:54
Lower control arm, stabilizer bar, tie rod
عمر شمس
عمر شمس2022-12-01 18:55
It might be an issue with the steering gear.
Hey folks, has anyone experienced their 206 having an unstable idle, with the needle going up and down? The dashboard backlight and interior lights keep flickering. What's broken here?
Hey folks! Anyone else experiencing this with their Yizhi? What's the issue with the idle speed fluctuating when starting a cold car? Sometimes it hits 2000 RPM right after starting.
What could be causing the steering wheel of my 2009 Lancer Sport to shake left and right while driving normally?
What could be the problem with the 86? When I make a slightly sharp left turn, the traction control activates, even though the ground is dry and there's no rain. It doesn't happen on right turns, and the car isn't skidding; I'm maintaining a steady speed. I've been to the mechanic, but they couldn't find the issue, and I've also done a wheel alignment. [Crying][Crying]
I have a 2019 GS5, and since early August, there's been a buzzing noise when driving between 60-100 km/h. It feels like I'm flying a plane, especially when I turn right, it gets louder. The dealership said it was a wheel bearing issue, so I had the bearings replaced, then the tires, and even the half shaft, but the problem still isn't solved. Has anyone else had this kind of issue? Please point me in the right direction. I don't want to keep wasting money and time on blind repairs. [About to cry]
Four years, 40,000 km, 1.5T F56. There's noticeable shaking and noise at idle. Is this common for everyone? I bought it second-hand, so I'm not sure how it was when new. Also, when driving on rough roads, there's noise from the left and right side windows. When the windows are down, there's no noise. I suspect it might be the frameless doors causing the glass to rub against the body. Does anyone else experience this?
My Jietu X70 has run 30,000 km, and when I cold start it, the idle is unstable, and the car shakes. After about ten seconds, it gets back to normal. There's no error displayed. I left it at the 4S shop for a week, and they cleaned the throttle, carbon buildup, and fuel injectors, but it didn't help. The 4S guys said it might be the fuel, so I switched gas stations, but there's still no change. Has anyone else experienced this? How did you solve it? Please let me know. 🙏
I recently bought the 2024 Tiida Intelligent Edition and it's my third time driving on the highway. When I reached 130 km/h, I noticed that after exiting the highway, the steering wheel needs to be slightly turned to the right to go straight. If I keep it centered, the car veers to the left. Is this normal? Also, is getting a wheel alignment expensive?
