اسماعيل حسن
2020-07-02 11:22
Hey folks, has anyone experienced their 206 having an unstable idle, with the needle going up and down? The dashboard backlight and interior lights keep flickering. What's broken here?
فهد قاسم
فهد قاسم2022-07-28 02:03
The first issue with the unstable idle is due to oil leaking from the two covers on top of the engine, getting into the spark plugs. The dashboard lights flickering is because oil has entered the alternator, causing it to generate power inconsistently and insufficiently, leading to low battery charge. This makes it difficult to start the car.
عبدالله عابدين
عبدالله عابدين2022-07-10 19:04
Generator, generator, generator.
حسن تاج
حسن تاج2022-06-23 00:10
The generator's voltage is unstable, you should go to the repair shop and have the technician measure the generator voltage.
عبد العزيز هكيل
عبد العزيز هكيل2020-07-02 11:34
In this case, you need to check if the vehicle's battery negative terminal is loose, which could cause this issue. Additionally, check if the battery charge is low or if there are any wiring problems. All these need to be inspected.
I'd like to ask the experienced folks here! For the Vitara 4WD, when driving on the highway, does it feel unstable when crossing bridges?
Hey folks, my '09 1.4 manual has a really light steering wheel, and it keeps wobbling left and right over bumps. Also, there's a slight shake at idle. What's going on? [Crying]
Is anyone else experiencing unstable idling with the new BRZ? Even without the AC on, whether the car is cold or warm, the gauge needle fluctuates noticeably.
For the 2023 Model X, there are several accessories you can consider to enhance practicality beyond the basic seat covers and floor mats, especially for your 5-seater version. Here are some suggestions: 1. **Trunk Organizer**: Helps keep your trunk tidy and maximizes space usage. 2. **Sunshade**: Protects the interior from heat and UV rays, keeping the cabin cool. 3. **Screen Protector**: Prevents scratches and reduces glare on the touchscreen. 4. **Wireless Phone Charger**: Convenient for charging your phone without cables. 5. **All-Weather Floor Liners**: Offer better protection against dirt and spills. 6. **Roof Rack**: Adds extra storage capacity for trips and outdoor activities. 7. **Console Wraps**: Personalizes the interior and protects from scratches. 8. **Portable Vacuum Cleaner**: Keeps the interior clean, especially useful for families or pets. These accessories can improve the functionality and comfort of your Model X.
Hey folks! What's going on with the dashboard lights flickering on and off in the middle section?
If you're considering the Jetour X70, there are a few things to keep in mind. Here are some pros and cons based on general feedback: Pros: 1. **Design**: The Jetour X70 is often praised for its stylish design and aesthetic appeal, which seems to be one of the reasons you're considering it. 2. **Space**: It typically offers a spacious interior, making it comfortable for families and long trips. 3. **Features**: The vehicle usually comes equipped with a range of features that enhance comfort and convenience. Cons: 1. **Manual Transmission**: If you're looking at the manual version, consider whether you prefer this over an automatic, especially in heavy traffic conditions. 2. **Brand Recognition**: Jetour might not be as well-known as some other brands, which could affect resale value and brand trust. 3. **Performance**: Depending on your expectations, the performance in terms of horsepower and Fuel economy might not match some competitors. Overall, it's important to weigh these aspects based on your personal needs and preferences. If possible, test driving both the Jetour X70 and Jetour Dasheng could help you make a more informed decision.
