أحمد علياء
2024-08-30 10:51
When I turn on the air conditioning, the cooling fan starts spinning, then stops after a while. The cycle of spinning and stopping is roughly one minute. Even after turning off the car, the fan keeps running and won't stop. Only by restarting the car and then turning it off again does the fan stop. Could the temperature sensor be malfunctioning? Any insights from the experts?
نايف حافظ
نايف حافظ2024-08-31 06:55
Normal cooling
يزيد فهد
يزيد فهد2024-08-30 15:42
Not encountered.
When I stop my KIA Soluto, turn off the engine, and shut everything down, after about a minute, there's a strange noise. It sounds like a locking noise, but it's not exactly that. Does anyone else experience this with their automatic transmission? Does anyone know the reason? Please let me know.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
When I turn on the car lights, there's a buzzing sound, like a fan cooling down. Has anyone experienced this? How should I fix it?
How do I turn off the auto start-stop on the ILX? 😅
How do I turn off the engine start-stop system?
After replacing the battery in the 2019 Ford Territory, the auto start-stop feature is always on unless manually turned off. What's happening?
Is it normal for the fan to frequently turn on, with a particularly loud noise, and then stop after a while, even when the water temperature is normal? Has anyone experienced this? It also happens when idling, where it turns on once every few minutes.
Hey guys, I noticed something today with my Sharan. The compressor starts running as soon as I turn it on, but the fan doesn't spin! The fan only starts when I turn on the AC. Is yours the same way?
Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
Peugeot Peugeot 2008
Peugeot 2008AED 69,900 ~ 169,900Diesel & Electric & Gasoline & Petrol
