عبدالله حاتم
عبدالله حاتم
Jul 22
The 2008 model doesn't have automatic air conditioning or physical buttons for the AC, making it hard to adjust to a comfortable setting. Frequently using the screen to adjust can be distracting. Do you have any good solutions for this? Also, it's been raining a lot recently, causing more fogging. Turning on the defogger feels like hot air, and when you turn it off, you need to adjust the AC again. 🤔
Comments( 10 )
أحمد أبشير
أحمد أبشير2024-08-19 14:48
There are two physical buttons for the air conditioning.
صادق حسين
صادق حسين2024-08-16 10:29
When the humidity is high, don't turn off the internal circulation.
عمر عرفات
عمر عرفات2024-08-04 20:41
Afraid of heat and with poor air quality in the city, I never open the windows. I keep the air conditioning at the coldest setting all summer, and I don't find it troublesome at all.
خالد بشار
خالد بشار2024-08-03 22:24
Generally, start by setting it to max, and when it gets warm, turn it to the minimum. No need to touch the screen.
عبدالرحمن زايد
عبدالرحمن زايد2024-08-01 00:13
Exactly! The only thing I'm not satisfied with is the air conditioning controls. After defogging, I have to press the button again. It's like they really want us to play piano with those piano keys. [I need a moment]
حسين موسى
حسين موسى2024-07-23 18:42
I used to think piano keys were fancy, but after trying them out, they're not as practical as two knobs. [I want some quiet time]
علي ميمون
علي ميمون2024-07-23 08:13
In the summer, my screen interface always shows the air conditioning [shocked].
نايف حافظ
نايف حافظ2024-07-23 05:56
The air conditioning controls are really inconvenient!
سعود زيلاخ
سعود زيلاخ2024-07-22 23:44
Can the volume knob be modified to adjust the air conditioning temperature?
سلمان شجاع
سلمان شجاع2024-07-22 20:42
I agree, the screen isn't very convenient to use.
Hey everyone, just wanted to ask: Why does the JETOUR X95 blow hot air when I turn on the seat ventilation? Thanks!
When the air conditioning blows cold air for a while and then switches to hot air, and after being turned off for a bit, it works again before reverting to hot air, it's puzzling. Interestingly, this issue doesn't occur on rainy days or when the weather isn't too hot. What could be the cause of this situation?
The AC in my 2017 Peugeot 308 starts blowing hot air after a while, and the fan near the radiator isn't working. What's causing this problem? Does it require major repairs?
When I turn on the AC in my 2019 Taurus, the rear vents blow hot air. What could be the reason for this? Can anyone help explain?
When the air conditioning is turned on in the 3008, it triggers an alarm, but it goes back to normal when the AC is turned off. What could be the problem and how can it be resolved?
Hey guys, the AC isn't cooling and is blowing hot air. When I turn on the AC, the compressor doesn't work, even though it's new. The repair shop said the fuse box has a bad connection and replacing it would cost over a thousand. What should I do?
To turn on the heater without the AC light coming on, you usually need to adjust the settings on your car's climate control system. Make sure that the AC button is turned off. If your car has an automatic climate control system, try switching to manual mode and adjusting the temperature and fan settings manually. If the AC light still comes on when you activate the heater, it might be due to the car's design to dehumidify the air, in which case you may need to consult your vehicle's manual or contact a service center for further assistance.
Peugeot 2008
Peugeot 2008BHD 5,990 ~ 10,495Diesel & Electric & Gasoline & Petrol
