هادي نايف
2024-07-12 05:24
Is everyone's air conditioning vent working fine? I feel like there's not much airflow to my feet...
علي ميمون
علي ميمون2024-07-20 07:11
In foot-blowing mode, the passenger side feels cooler than the driver's side, as if something is blocking the driver's side. Also, when I set it to level two and turn on both the face and foot vents, there's almost no air coming from the foot vents.
فهد إدريس
فهد إدريس2024-07-19 23:39
No matter which direction I blow the air, the front windshield always fogs up. The car isn't even that cold inside, yet the front windshield still gets foggy. I'm considering blocking the vent for the front windshield.
فهد عبد لطيف
فهد عبد لطيف2024-07-12 07:54
On the contrary, there's a draft blowing on my feet. They're freezing cold.
The rear air conditioning vents are not blowing cold air?
How much is the actual city range with the air conditioning on?
For the 2017 model, if the central control air conditioning vent is weak and you hear a loud noise from the air conditioning even when it's on maximum, but there's not much airflow, how can this be resolved?
Hello everyone, I want to ask, my car is 3 years old now and there's a strange noise coming from the steering. The air conditioning isn't working well either. Are these common issues?
How to remove the air conditioning vent louvers?
Will it affect the air conditioning if the navigation clip breaks and falls into the air vent? Do I need to take it out?
I want to ask the experts, why does the air conditioning not work when I turn on the internal circulation? The light comes on briefly and then goes off, but the heating works fine. Why is that?
Hello everyone! Is it common for the rear air vents in the Outlander to have low airflow?
Hi everyone, I need some advice. I have a 2016 Nissan X-Trail with 70,000 km on it. The AC blows cold air for about 10 minutes, but then the airflow decreases. If I turn off the AC for a while and then turn it back on, it works fine again, but after a few minutes, the airflow decreases once more. Alternatively, if I turn off the AC, the airflow increases, and when I turn the AC back on, it runs normally, but after about 10 minutes, the issue returns. What could be the problem? Thanks!
Peugeot Peugeot 2008
Peugeot 2008AED 69,900 ~ 169,900Diesel & Electric & Gasoline & Petrol
