عبدالله تكريتي
2024-10-01 23:58
If the engine isn't turned off, can the doors not be opened from the outside? I'm new to this, and it was awkward twice today. 😅
عبدالله تكريتي
عبدالله تكريتي2024-10-04 19:01
Where can I check the fuel consumption?
عبدالله تكريتي
عبدالله تكريتي2024-10-04 19:00
Thank you, everyone.
عبد العزيز علياء
عبد العزيز علياء2024-10-04 14:54
Turn off the lock button on the center console, and then it can be opened from the outside.
أحمد عرفات
أحمد عرفات2024-10-04 14:37
There's a lock button on the central console. Press it once, and it can be opened from the outside.
علي عادل
علي عادل2024-10-02 08:49
There is a lock button on the central control. Just press it once, and it can be opened from the outside.
How do you unlock the child lock on the 19zs rear door? It's annoying that the door can only be opened from the outside.
For the 2012 Honda City, the doors can only be opened after turning off the engine. How can you set it to open the doors without turning off the engine? Also, when the car starts and you press the brake, the doors automatically lock.
How do I turn off the auto start-stop on the ILX? 😅
How can I prevent the rear lights from turning on as soon as the door is opened?
The child lock on the right rear door of the 2014 V60 is not engaged, but the door cannot be opened from the inside, only from the outside. What could be the issue?
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
I found a problem today, the taillights flashed by themselves. My friend and I were outside the car, the doors were locked, and we were less than two meters behind the car. The key was in my pocket, and the taillights flashed twice on their own, with about a thirty-second interval! What's going on!!! It's different from the hazard lights, it was a quick flash on and off. Is it haunted? 👿👿👿👿👿
The inner button on the passenger door isn't working, but it can be opened using the screen controls and from the outside. What could be the reason for this?
The rear door of the Jetour X90 Zilong Edition cannot be opened from both the inside and outside.
Peugeot Peugeot 2008
Peugeot 2008AED 69,900 ~ 169,900Diesel & Electric & Gasoline & Petrol
