أحمد خير الدين
2024-08-08 06:49
2020 top model, currently at 120,000 km. Started burning oil shortly after changing the belt at 100,000 km! Anyone else experiencing the same issue? 🤦‍♂️
Comments( 9 )
أحمد عرفات
أحمد عرفات2024-08-09 17:11
Where did you go to get it changed?
نايف حافظ
نايف حافظ2024-08-09 10:09
I changed it at 40,000 kilometers. Currently, there's no oil burning.
حسن ماجد
حسن ماجد2024-08-09 09:38
It seems like the belt was changed, right? Without the proper tools, you often have to remove the top cover. If it's not sealed properly during reinstallation, it can lead to issues. This is common with the National V emissions standard engines. After changing the belt, there might be oil burning problems. It's not a problem with the engine itself, but rather with improper maintenance and installation.
حازم أحمد
حازم أحمد2024-08-09 07:40
Some experts suggest replacing it earlier, at 3 years or 50,000 kilometers.
عبد العزيز صلاح
عبد العزيز صلاح2024-08-09 00:04
I have a 2020 mid-range model, currently with 20,000 kilometers on it. It's primarily used by my wife for commuting.
عبد العزيز صلاح
عبد العزيز صلاح2024-08-09 00:03
Was it replaced at a 4S shop or a specialized repair shop?
حسن جبريل
حسن جبريل2024-08-08 17:46
Is burning oil a serious issue? How many kilometers per liter?
عبدالرحمن شادي
عبدالرحمن شادي2024-08-08 09:13
What grade of engine oil is used?
علي علي
علي علي2024-08-08 08:46
Hasn't the China VI emission standard been completely resolved?
The noise at high speeds with the 2.0T engine is getting louder. I've had the car for two weeks, and it's currently at 2,500 kilometers. Does anyone else feel the same way? Any suggestions on how to fix it?
How should I deal with my Kia Sportage burning oil after 120,000 km? Does it need a major repair? Has anyone else experienced this? Can you share your thoughts?
Hello everyone! My 11-year-old Sunny with a manual transmission has run 100,000 kilometers. Do I need to change the belt now?
I changed the transmission oil at 40,000 km at the 4S shop, and now at 100,000 km, I'm planning to replace it for the second time. I'm considering using Shell CVT transmission oil. Has anyone tried it? Is it okay to just clean the metal filter?
Hey fellow car enthusiasts, my car seems to be burning oil. After about 7000 km on full synthetic oil, the dipstick shows it's almost at the minimum level 😭. This has happened in the last two maintenance sessions. It's a 2017 Jeep Compass with 120,000 km over 6 years. Has anyone else experienced engine oil burning, and how did you resolve or repair it?
When driving at 60-80 km/h, I hear a buzzing noise coming from the front of the car. It gets a bit better when I speed up. I initially thought it was a bearing issue, but after replacing it, the noise is still there. What could be the cause? Could it be the belt, transmission, or something else? (The car has 130,000 km on it.)
I've been driving a 2009 Kia Sportage manual GLS with 120,000 km on it. I've always used 5W-30 engine oil, but recently it seems to be burning oil a bit. Should I switch to 5W-40 oil for maintenance? Has anyone experienced this before and can share some insights?
Car enthusiasts, do you think that by changing the gear ratio and using 95 octane fuel, there's a chance to reach a top speed of 190 km/h? 😁
After changing the transmission oil at 80,000 km on a 2014 Tiida, there is a fluctuation in the RPM from 2000 to 2200 when driving at around 120 km/h, and the car feels jerky. I went to the 4S shop, but the transmission didn't report any errors. Has anyone else experienced the same issue?
Peugeot Peugeot 2008
Peugeot 2008AED 69,900 ~ 169,900Diesel & Electric & Gasoline & Petrol
