عبدالرحمن سا مرعي
2024-08-09 22:17
2014 Peugeot 2008 manual transmission, the remote key can't unlock the driver's door (can open with the key), while the other three doors work fine. Any advice on how to solve this issue? 🙏🙏🙏
علي ميمون
علي ميمون2024-08-13 08:37
The driver's door has been opened and closed frequently over time, and the repeated impact has made the remote control sensor for the driver's door less responsive. It's normal, better get it checked. It's time for a replacement; using the key back and forth is quite a hassle. [I need some peace]
It seems like your 2011 Phaeton is experiencing some issues with the remote unlocking and the keyless start system. Sometimes you have to use the mechanical key to lock and unlock the car, and the keyless start doesn't work. Occasionally, after using the mechanical key to start and then turning off the engine, the remote unlocking and keyless start work fine again. What could be the problem?
My Previa's remote key won't unlock the doors, even after changing the battery. What's going on? Fellow car owners, can you please advise on how to fix this? Thanks a lot!
I disassembled the Peugeot 301 key and moved the chip to a new case, with the metal key separate. Now, the remote can unlock the door, but the metal key won't start the car. Could it be the key issue that's causing the car not to start?
After locking the 2.0 manual ASX, the remote works fine, but why can't it be opened with the key? Any ideas?
For the 2009 Yuxiang, the driver's door often won't open. I have to lower the window and use the mechanical key from the outside several times. The other three doors are fine. Can someone tell me if this is a common issue with the old Yuxiang? [Facepalm]
The car battery is dead, how to lock the car doors? Currently, the mechanical key can only lock the driver's door.
Has anyone replaced the key battery before? After I replaced the car key battery myself, I can remotely lock and unlock the doors without any issues, but the car won't start when I insert the key. The anti-theft system isn't connecting. Does anyone know how to solve this?
Why does the driver's door not open with the key unlock button after locking the car from the outside, while the other three doors can be opened?
If the remote control function of your Peugeot 307's key is not working, even though the key itself is in good condition, what could be the issue?
Peugeot Peugeot 2008
Peugeot 2008AED 69,900 ~ 169,900Diesel & Electric & Gasoline & Petrol
