Where can I still buy a Polestar 2 from a reliable source? I went to the official store and they only have the Polestar 4. (I'm willing to search nationwide for the car.)
I went to the HiPhi store today. Is there only one key, no card key?
To determine whether your Jeep Compass is equipped with an AT (Automatic Transmission) or CVT (Continuously Variable Transmission), you can check the following: 1. **Owner's Manual**: Refer to your vehicle's owner's manual, which should specify the type of transmission. 2. **Vehicle Documentation**: Check any official documents related to the vehicle, such as the purchase agreement or service records, which might indicate the transmission type. 3. **Under the Hood**: Look at the transmission system under the hood. Sometimes the transmission type is labeled on the transmission unit itself. 4. **Vehicle Identification Number (VIN)**: Use the VIN to decode the specifications of your vehicle. Websites or services that provide detailed vehicle information based on VIN can help you identify the transmission type. 5. **Contact Dealership**: Reach out to a Jeep dealership with your VIN. They should be able to provide you with detailed information about your vehicle's transmission type. If there is conflicting information from different sources, the dealership is likely your most reliable source.
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
4Yesterday, I went for a car maintenance, and the oil draining took a bit longer. The mechanic said that adding just over 4 liters of oil wasn't enough, so they added a bit more, totaling 5 liters. Is this reasonable?
5Just got the car 2 days ago. When I picked it up, it showed 435, but it seems like I've only driven less than 300, with a bit over 90 left, so I went to charge it. Is this normal for city driving?
6How to download WeChat on the x90Pro: 1. Open the app store on your x90Pro device. This could be the Google Play Store for Android devices. 2. In the search bar, type "WeChat" and press enter. 3. Find the WeChat app in the search results and click on it. 4. Tap the "Install" button to download and install the app on your device. 5. Once the installation is complete, open the app and follow the on-screen instructions to set up your account or log in.
7Hello Polestar 2 owners! My family is considering getting an electric car for my wife, with a budget of around 100,000. We're worried about buying a new electric car and then regretting it later, so we're thinking about getting a used Polestar 2, either the 2020 launch edition or the 2021 model. I want to ask if this car is reliable as a second-hand option and if the range is dependable. Is it still a good choice to buy?
8The official store has given vouchers for car covers and car films. I'm wondering if purchasing from the official store would be more reliable.
9With a budget of 12w, which year and model of Polestar 2 can I buy? I've seen on Douyin that this car is pretty good.
10Is there any owner who has experienced a clunking noise from the chassis when making a U-turn with the steering fully turned? I went to the 4S store, and they said it's a problem with the half axle and needs replacement. Has anyone else encountered this?
