Is there any play in the steering of the Mazda 2? Does it make noise on bumpy roads? Has anyone replaced the steering gear? Is there a difference between OEM and aftermarket parts in terms of driving experience?
Is this Mazda produced by FAW still similar to Japanese imported cars in terms of original parts and assembly methods? Some users aren't quite impressed with its appearance. Are there any drivers who've used it? Can you evaluate its actual driving performance?
Has anyone experienced a rattling noise from the front of an '08 Mazda 5 when driving on bumpy roads? I've just replaced the front shock absorber assembly, lower control arm, tie rod end, sway bar link, and stabilizer bar bushing, but the noise persists. Any ideas?
Is there a significant difference in driving experience between the 2.5 and 3.0? I'm planning to buy a used Viano and later get a towed RV. Will a 2.5 engine struggle with towing a trailer? Normally, the 2.5 should consume more fuel compared to the 3.0, but since the car often idles for 1-2 hours waiting for people, would the 2.5 be more fuel-efficient in this situation?
4Is there any play in the steering of the Mazda 2? Does it make noise on bumpy roads? Has anyone replaced the steering gear? Is there a difference between OEM and aftermarket parts in terms of driving experience?
5Hey guys, my Land Cruiser tends to pull the steering wheel when driving on bumpy roads, and it doesn't feel very stable. I've already done a wheel alignment, and the mechanic said there's nothing wrong. Is the steering wheel pulling a normal phenomenon?
6Do you hear a sound like two wires colliding under the front left side of the dashboard when driving your Hyundai Reina on bumpy roads? It seems to be related to the steering gear. I've checked the chassis multiple times but couldn't find the issue. Have any of you experienced this problem?
7Hey fellow car enthusiasts, any recommendations for buying OEM parts? I'm about to get a Mazda 2 and will need some original parts both for initial setup and future use. Does anyone have any Taobao sellers they can recommend?
8I want to ask everyone about modifying a Patrol and the experience of using aftermarket parts for a few years. How's the quality and stability? Especially the LCD instrument panel and central control screen, do they black out when reversing? I'm thinking about getting modifications done.
9I bought a CX-30 earlier this year and I'm thinking of getting an Xpeng in four years. Can anyone compare them? Since the CX-30 is my first car, I'm not sure what a good driving experience feels like. Is there a big difference between driving an Xpeng and a Mazda? Since both cars are about the same size, the Xpeng with a 2.5 engine should be more powerful, right?
10Seeking advice from fellow car owners: 1. Is it normal to feel a slight vibration in the steering wheel when the air conditioning is on? 2. When using the standard + B mode, there's almost no brake dive, but when the auto hold is activated, the brake dive is quite noticeable. Do you experience this too?
