سلمان بهاء
2024-10-31 18:05
Is there a way to upgrade to adaptive cruise control?
عمر انهايان
عمر انهايان2024-11-02 13:33
It seems like there are 24 models available, but it looks like it's not possible to flash them.
How to use cruise control?
Is there an ACC adaptive cruise control installed on the 2018 model?
Can the premium version, which only has cruise control, be upgraded to adaptive cruise control?
Does this car have cruise control?
The difference between canceling cruise control and turning off cruise control in a Patrol is essentially about how the system is deactivated. Canceling cruise control is a temporary deactivation, allowing you to resume the set speed later, while turning off cruise control completely deactivates the system until you set it up again.
The difference between the "Cancel Cruise" and "Turn Off Cruise" buttons on the steering wheel of a Patrol is as follows: - **Cancel Cruise**: This button temporarily deactivates the cruise control while keeping the set speed in memory. You can resume the cruise control to the previously set speed later without having to set it again. - **Turn Off Cruise**: This button completely deactivates the cruise control system and clears the set speed from memory. To use cruise control again, you would need to set the speed anew.
Can the 2019 EcoBoost 245 Yuexiang Edition be upgraded with lane departure warning and adaptive cruise control?
Can we retrofit adaptive cruise control (ACC) on our Territory?
Does the 2023 Macan 2.0T come with standard cruise control or adaptive cruise control? Can someone explain this?
How well does the car's adaptive cruise control work in traffic jams? Is it practical? I'm only interested in its performance in traffic jam situations.
Polestar Polestar 2
Polestar 2AED 179,900Electric
