I want to replace the spark plugs myself, but I'm not sure where they are located. How do I replace them?
I'm not sure where the VIN is located on the Toyota Sequoia's frame.
Hey buddies, does anyone know where the air conditioning filter is located in the Koleos? I want to change it myself but I don't know where it is (⊙o⊙)!
Where are all the drainage outlets of the Jetour X95 located, and do I need to open them myself?
4I want to replace the spark plugs myself, but I'm not sure where they are located. How do I replace them?
5The 2022 Haval H9 is approaching 40,000 kilometers, and I'm not sure how much longer the original spark plugs will last. Fellow car enthusiasts, at how many kilometers did you change your spark plugs? What condition were the spark plugs when you replaced them? Thanks! ***** Also, I've clearly stated it's the Haval H9 and posted this in the Haval H9 section. Please make sure it stays within the Haval H9 circle and not other H9 circles. It's really tiring, you're quite something! *****
6Should I replace the battery at the 4S shop or do it myself? I'm torn.
7Yesterday, I went for maintenance and replaced the spark plug assembly. I want to ask, after a year and having driven 20,000 kilometers, is it necessary to replace it?
8Does anyone with a V40 have a source for chassis bushings? I want to buy them myself and then find a repair shop to replace them.
9Hey everyone, at how many kilometers did you replace your car's original spark plugs? I'm at 80,000 km now, and the car starts up instantly. Not sure if I should replace them.
10How do I remove the glove box? I want to replace the air filter myself.
