حسين أمير
2023-05-16 22:24
How to properly use the Polestar 2 battery, which is better between fast charging and slow charging, and do I need to regularly calibrate the battery? 😵
سعود فارس
سعود فارس2024-06-26 16:29
Does the initial release version have both slow charging and fast charging ports?
حسن جلال الدين
حسن جلال الدين2023-05-17 12:15
I've been using it for over half a year, fast charging less than 10 times, and it feels fine.
خالد جليل
خالد جليل2023-05-17 11:32
Used for two years, slow charged less than five times, feels fine. [I want to be quiet]
Complaint about the Volkswagen Lavida new energy vehicle. Major negative review: The battery lacks a cooling function. While charging at around 100A, the Lavida only charges at 28A to 30A at a fast-charging station, making highway driving really frustrating.
Is it better for the battery to charge the C40 electric car to 100% or 90% each time?
My E2, with a 47 kWh battery, charges up to 100%, but why does fast charging only add 35 kWh? I've already replaced the power battery due to the same issue, but the problem persists. Please help, it's urgent.
In six months, I've driven 7,000 kilometers and have been using fast charging outside all the time. The mileage and display match up normally. Recently, I noticed the power drop is significant—three times the usual rate. The 4S shop checked and found no issues, suggesting that it might be due to fast charging causing a false charge. They recommended using the original slow charger. Initially, using the original slow charger seemed fine, but recently, the power drop is double what the display indicates. After charging, sometimes it's good, sometimes it's not. What could be the problem?
I always charge when my battery is between 10-20%. I see many people start charging at 30%. Does charging at 30% really help protect the battery better? And do you guys wait until it’s 100% full before unplugging?
Why is the fast charging limited to a maximum of 19.5kW? It takes a bit over 2 hours to fully charge.
Has any owner of the 3-motor version of the XP noticed a 4% drop in battery health after six months? I personally feel that I've taken good care of the battery, usually charging between 50% to 80% (slow charging), rarely using fast charging, and charging to 100% no more than five times. When not in use, I keep it plugged in and haven't driven aggressively or used the straight-line speed mode. Despite this, the battery health has still dropped by 4% in six months. Is anyone else experiencing the same thing?
With a budget of 12w, which year and model of Polestar 2 can I buy? I've seen on Douyin that this car is pretty good.
Hello everyone in the Leapmotor community, I have a question. Can you unplug the charging gun during slow charging at home? This morning at 6 o'clock, while I was sleeping and the car was charging, my father needed to use the car. He directly unlocked and unplugged the gun to drive away. This raises my doubts: Can the Leapmotor C11 pure electric model be directly unplugged during slow charging? First, does this operation pose any threat to personal safety? Second, will this affect vehicle safety? Third, will it impact the battery? If it's an incorrect operation, how should one correctly stop using the car during charging?
Polestar Polestar 2
Polestar 2AED 179,900Electric
