سعود أنس
2022-09-25 22:59
Hey fellow car enthusiasts, I just got an '09 Mazda2. I wanted to ask if there are any common issues I should be aware of. Also, is the Mazda2 prone to burning oil? I'm really concerned about the oil burning issue. Thanks!
عمر فهد
عمر فهد2022-10-02 21:34
Everything is normal, but the sound insulation is a bit poor.
سعود أنس
سعود أنس2022-09-26 22:51
Is there a car enthusiasts group that I can join? 🌹
عمر مرشد
عمر مرشد2022-09-26 10:26
So far, I haven't experienced any oil burning issues. But I don't drive much; I bought it in 2009 and have only driven 6,500 km. According to a friend who knows about used cars, as long as the Mazda 2 is driven normally and maintained properly, there's no worry about it breaking down.
I bought a used Liana and it's burning oil. What should I do?
Is there a solution for the Kia Sportage valve cover oil leak? Is it a common issue? I bought a 10-year-old manual second-hand car.
I'm considering buying a second-hand 2012 XV. Does the 2012 XV consume engine oil excessively, and are there any issues I should be aware of?
The oil light came on while driving the 2012 XV at high speed. I went to the repair shop, and they said it's burning oil. What should I do?
I bought an '09 Accent and it's burning oil. What should I do? At 80 mph, the RPM is over 2000, and when I accelerate more, it vibrates a bit. Is there a problem? Can it go on the highway?
Is oil consumption a common issue for the Mitsubishi Eclipse Cross? How should it be repaired?
Navara 2019 model, currently has over 60,000 kilometers. When changing the spark plugs, there was oil in the cylinders. The 4S technician said the valve cover needs to be replaced due to internal leakage and should be replaced together. I want to ask everyone, is this a common issue with the Navara?
Is it a good idea to buy a used 2016 Subaru Legacy? Are there any common issues I should be aware of? Looking for advice from the experts!
I would like to ask if the stability of the Peugeot 308 1.2T has improved a lot after the 2018 model? Or is it still the same as before, with issues like oil burning and cylinder scoring? Can any real car owners share their experiences?
