سلمان هاشم
Oct 31
Hey car enthusiasts, need some advice. For a 20" launch edition, what's the ideal tire pressure? I often drive fast and there's no load, just me. The A-pillar suggests 28 psi for the front and 30 psi for the rear. Isn't that too high...?
لبيب علي2024-11-04 11:57
You might have misread it. The standard cold tire pressure for a light load is 3.0 front and 2.8 rear. For heavy load and economy cold tire pressure, it's 3.0 front and 3.1 rear. I set the pressure 0.1 lower than the standard for better grip and to reduce bumpiness.
سعود فارس2024-10-31 14:18
For the front tires, at least 2.8 is needed. As for the rear tires, it depends on your load; if there are no passengers or cargo, 2.8 is sufficient as well.
عمر كريم2024-10-31 12:40
The rear 3.0 is the full load tire pressure.
