لبيب علي
2024-03-16 18:50
At extremely low speeds, there's a crisp sound from the relay contact when kinetic energy recovery engages. In creep mode, it occurs just when the brake is applied during low-speed crawling. Without creep mode, it happens when you release the accelerator at low speeds. It's just one crisp sound, coming from near or in front of the pedal. The sound is very faint, and can't be heard with the windows open, music playing, or on a bumpy road. This is with the first launch of the dual-motor. Has anyone else encountered this issue, and can it be fixed?
محمد بارزاني
محمد بارزاني2024-06-17 01:01
I think it's something like the air conditioning deflector. The sound is coming from inside the dashboard right in front of me. Last summer, there was an occasional continuous tapping sound, but in winter, when the air conditioning wasn't used much, it didn't happen. Recently, it's been hot again, and the sound has returned. Usually, the car is parked in the garage.
نايف نصر
نايف نصر2024-04-03 17:42
That's normal, everyone has it. I'm currently puzzled by a sharp, bird-like noise coming from the wheels when I open the windows at low speed. It's quite annoying.
حسين همام
حسين همام2024-03-21 04:34
There's a strange noise when lightly braking with the standard energy recovery system.
علي خدي
علي خدي2024-03-18 13:07
When I start at low speed, there's a faint noise, like a "thud," coming from the area near the left pedal. It's not like a mouse click. Not sure if this is the same issue you're talking about.
رومي عمر
رومي عمر2024-03-18 10:00
It sounds a bit like clicking a mouse. Cars with CRBS generally have it, just the volume varies. Don't worry too much about it. [I want to be alone][I want to be alone]
When I turn the steering wheel to the left, there's a strange noise like the brakes are being applied. It doesn't happen when driving at high speeds or when turning right, just goes "zhi, zhi!" Can any expert help explain this?
When the windows are closed and the music is off, I can hear a faint ticking noise while gently pressing the accelerator in park mode. It seems to come from the center console, like a small motor vibrating. When I press the accelerator hard, the sound disappears. I can also hear it occasionally when driving at low speeds or when releasing the accelerator. The noise is noticeable when starting the car cold, and it feels like a metal-on-metal vibration or collision underfoot. Interestingly, after driving for a while, the sound goes away. However, if the car is stopped for a while and then started again, the noise returns initially but disappears after driving for a bit.
When driving at low speeds and turning the steering wheel, the 2014 XV experiences significant body vibration and loud noise. However, this issue does not occur when the car is cold and has just started. I want to know what the reason could be? Does anyone else have the same situation?
Is the 2022 GA6 experiencing jerking when shifting from second to third gear and also when accelerating at low speeds in third gear a common issue for this model?
I have a Mini Clubman 2.0T, and when starting or at low speeds, I hear a kind of loose rattling sound, similar to a "license plate not tightened" noise, when I press the accelerator. I'm not sure where the sound is coming from. Does anyone else with a Mini experience this?
Hi everyone, just wondering if the steering wheel of the Skoda Rapid doesn't return automatically when driving at low speeds?
There is a "clunk" sound when applying the brakes to stop.
I have a 2022 manual version, and I'm hearing a clunking sound when turning at low speeds. What could be causing this??? Any ideas!!!
Does anyone with a 2022 Forester experience a rubbing sound from underneath the car when driving at low speeds with the AC on?
Polestar Polestar 2
Polestar 2AED 179,900Electric
