عبد العزيز ابراهيم
2024-08-31 18:33
The newly introduced 009 has a comfortable entry and exit feature. However, every time I get into the driver's seat and press the brake, it doesn't restore the previous settings. I have to tap the upper left corner avatar and then select the previously saved driving preferences, which is quite troublesome. Does anyone know how to fix this? Thanks!
فهد ق2024-09-28 18:36
After some research, you can add a scene workshop with the condition that the driver enters and closes the door, and then the driving habits are executed. Where can I turn off this comfort entry/exit feature? Every time the door opens, the space behind the second row driver's seat becomes smaller.
عبدالرحمن عامر2024-09-09 15:39
Me too.
عبد العزيز ميثا2024-09-02 08:41
In situations like this, especially the first time you start the car each day, you often have to do it manually. The older models didn't have this issue at all.
عبد العزيز سليم2024-09-01 06:46
There's no solution; it's a car system bug that needs an OTA update to fix.
نايف باسم2024-08-31 21:34
Yes, sometimes it's possible, sometimes it's not.
