Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
Is the long-range version just a bigger battery replacing one motor? [Facepalm]
How to choose between the Volvo C40 Long Range Pro and the Tesla Model 3 Standard Range?
4Yellow, Flash Zinc Gray, or Shimmer Rhodium Silver, which one should I choose? Any advice from fellow car enthusiasts?
5Does the Model X have a 2019 Standard Range version? Is the suspension the new version? Apart from battery capacity, what are the differences compared to the 2019 Long Range version?
6Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
7I want to ask everyone if the ground clearance of the Zeekr X is high. Is the battery integrated with the skid plate?
8My new 009 with a 108 kWh battery and all-wheel drive has a dynamic range of 525 km. Is that too low? How about yours?
9Hey fellow car enthusiasts, my Song Plus flagship model suddenly lost power, but the battery check shows no issues. Has anyone experienced this before? How did you solve it? Thanks in advance for any advice!
10Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
