عبدالرحمن عامر
2024-09-09 15:40
My new 009 with a 108 kWh battery and all-wheel drive has a dynamic range of 525 km. Is that too low? How about yours?
Comments( 10 )
عمر فواز
عمر فواز2024-09-27 14:59
How's the range?
حسين عاطف
حسين عاطف2024-09-26 11:13
I think the Zeekr 001 Dynamic 550 is pretty much okay like this.
عبد العزيز أرسلان
عبد العزيز أرسلان2024-09-26 10:27
If fully charged and driving at a constant speed of 100, it can run 550.
عبدالرحمن ميمون
عبدالرحمن ميمون2024-09-23 01:11
With a steeper incline, you won't even reach 450.
شخبوط نايف
شخبوط نايف2024-09-19 22:57
It seems like you've managed to control your energy consumption quite well. Can I ask what the kilowatt rating of your home charging station is?
أحمد رأس
أحمد رأس2024-09-18 09:04
A full tank of fuel in a gasoline car only lasts about 500 kilometers.
حسين عفان
حسين عفان2024-09-15 15:21
500 is really good.
حسن عبد الوهاب
حسن عبد الوهاب2024-09-12 00:27
Having 500 is enough for me; I can handle both short and long trips.
خالد عرفات
خالد عرفات2024-09-09 23:15
Around 500 is normal, right?
حسين مأمون
حسين مأمون2024-09-09 21:23
The current temperature is around 500, which is already satisfying. When the weather is a bit better, it should reach around 550.
For a 2018 Model S 100D with 80,000-90,000 kilometers, the remaining battery range can be significantly different compared to a 2022 Model 3 or Model Y with a 78 kWh battery. The older Model S may experience some battery degradation over time, affecting its range. When considering a used car, it's understandable to be concerned about the battery's performance and capacity.
What is the real energy consumption of the Model S 100D Long Range version? How many kWh per 100 km? Please share some images! I currently own a Model 3 Long Range with an energy consumption of 12.4 kWh per 100 km. I'm planning to buy a new Model S. Any advice from experts would be appreciated, mainly considering range and comfort!
The news says the new version has a 670 km range. Does anyone know when it will be released?
50 kWh can achieve a range of 400 km, and 66 kWh can reach 615 km. Does a longer range mean the battery is lighter and more efficient? These range claims seem too arbitrary!
What's the actual range for the high-end all-wheel drive C40? I'm getting between 300-400 km. Is that normal?
Has anyone managed to achieve a range of 780km on an 82 kWh battery, or experienced the corresponding energy consumption?
To achieve a 690 km range, how many kilowatt-hours (kWh) are required for a full charge?
Why is the computing power of the new Zeekr 009 so low? Is it using Mobileye's autonomous driving chip? Why not use the mainstream Nvidia?
Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
Zeekr Zeekr 009
Zeekr 009AED 400,000Electric
