I was told that the delivery for the Zeekr 009 would be in 3-6 weeks, but now they're saying it's going to be 8-9 weeks. They also won't refund the deposit, and their customer service is terrible. I'm considering legal action.
Comments( 9 )
I've had my car for a week, and the 4S dealership has forwarded my personal and vehicle information to the manufacturer to activate the customer service. But when I try to connect to the customer service phone from the car, it doesn't link up. Has anyone experienced a similar issue? If you know anything, please reply, thanks!
