عبد العزيز عَبْدُ الْعَزِيز
2024-08-22 22:06
I want to ask how many kilometers the 009 actually runs in a test if it claims 700 kilometers. I'm considering purchasing it recently.
Comments( 9 )
خالد يونس2024-09-03 15:26
4WD with a 108 kWh battery, in the city, a full charge typically gets you around 540 km.
عبد العزيز تاج2024-09-02 23:45
The 120 can run a bit over 400 kilometers, but not more than 420 kilometers. From 55% to 4% battery, it covered 210 kilometers in economy mode, with four adults and two kids, air conditioning set at 24°C. It feels not as good as the older model.
خالد لحود2024-08-25 08:22
108-degree four-wheel drive, a family of four, with the air conditioning and TV on, driving at highway speeds of 90-130 km/h. With good road conditions, we stayed close to the speed limit. The temperature was 28 degrees, and in comfort mode, we managed to cover just over 400 kilometers.
سعود طاهر2024-08-23 22:46
I have the single-motor version and haven't driven on the highway yet. I've driven on expressways at 100 km/h, and it seems like the full charge range is just over 600 km.
نايف مجدي2024-08-23 22:09
20% discount is reliable.
عمر طه2024-08-23 21:03
Those who say the max speed is only 300 probably haven't driven the 009. It's just too biased. Certified owners would just shake their heads. How can someone criticize the 009 like that? [Angry][Angry]
طلحة خالد2024-08-23 18:15
Top speed of 350 km/h! I guarantee it won't exceed 380 km/h!
أحمد شاكر2024-08-23 15:51
You can check out my post about energy consumption. The dual-motor setup runs about 30 to 40 kilometers less than the single motor, but it can still reach 500 kilometers.
حسين عفان2024-08-23 13:11
500 is no problem, but if you turn on all the AC, loudspeakers, and TV, then it might be a different story.
How many kilometers can it actually run?
How many kilometers can a single fuel tank of an FJ72 run?
Can this car run 700 kilometers on a full tank?
4I haven't seen actual test data on how many seconds it takes for Linbei.
5How many kilometers can the 1718 model X run on a full charge now? I'm considering buying a used one.
6The car actually runs 250 kilometers.
7I want to ask, how many kilometers can a 2019 HS7 3.0 V6 run on the highway with a full tank of fuel?
8How many kilometers can it run on a full charge and a full tank?
9I want to ask how many kilometers the 009 actually runs in a test if it claims 700 kilometers. I'm considering purchasing it recently.
10How many kilometers can the Zeekr 009 run at a highway speed of 120-130 km/h?
