محمد مجدي
2024-12-02 17:36
When you unlock your car, does the rear make a clicking sound? It should be the sound of the solenoid valve. Also, when you stop at a red light, does the air suspension always raise the height, making the front of the car lift up?
حسين شخبوط
حسين شخبوط2024-12-03 08:22
It seems like not all cars have it. I'm in the same situation as you.
خالد أسامة
خالد أسامة2024-12-02 17:41
The sound of the air suspension pump. I have it too, it's annoying.
After your ASX is turned off, can you hear a clicking sound from the air conditioning vents on the dashboard after about a minute?
Can you hear the engine making a "da da da" sound when accelerating your ASX?
When the suspension is raised to its highest level, after parking and turning off the engine, the vehicle sometimes lowers to a normal height. I haven't activated the easy entry/exit feature, and it doesn't lower immediately after turning off the engine. Sometimes it doesn't lower at all, while other times it lowers on its own.
Gv80 shifts to neutral at a red light, makes a thump sound when starting.
After turning off the engine and locking the car, the driver's side window automatically rolls down. While driving, the driver's window button is sometimes responsive and sometimes not. Whether raising or lowering, once the button is pressed, the window moves directly to the bottom and won't stop in the middle. After reaching the end, you can still hear a clicking sound inside the door panel. Is the window button broken? Could you provide a replacement tutorial, preferably with a video?
Is anyone else experiencing the issue where the air conditioning vent actuator motor is broken and makes a clicking sound when powered on?
While driving the KAMIQ, a red "P" appears on the dashboard, accompanied by a beeping sound similar to the seatbelt warning. What could be the issue? Thank you!
Fellow car enthusiasts, how often do you replace your solenoid valves? Mine needs replacing every year, and this year I've already replaced two.
2016 model Touran L's air conditioning starts cooling, but stops after a while. Replaced the solenoid valve and cleaned the control board, it worked for two days and then the issue reoccurred. Has anyone experienced this? How did you solve it?
What could be the reason that the remote key can't lock the car? When I press the lock button on the remote, I hear two clicking sounds, and then it automatically unlocks. I'm desperately seeking answers from fellow car enthusiasts. 😬
Zeekr Zeekr 001
Zeekr 001AED 226,900 ~ 271,900Electric
