Just a year and three months, and the Bluetooth car key is already broken? My old fuel car key lasted eight years without even changing the battery. It's really funny that the key for this Zeekr needs a battery change every six months and can't be used after a year... Also, this key can't be repaired by Zeekr themselves; it has to be sent back to the manufacturer for a paid repair, or you need to buy a new key. 👍 After browsing through the car owners' forum, I found out that the car key is actually the least noticeable issue. Is Zeekr's quality control really this bad now?
Comments( 6 )
I'm making 5000 a month. How many years do I need to work to afford it?
How do I change the battery for the 2022 model car key? What type of battery does it use?
I just want to ask, does the Levante really need a lot of repairs?
4My MG ZS often has the gear indicator light go off, and I can't shift it into the P gear. It's happened four or five times now. It's really frustrating, this car keeps needing repairs.
5Does it need a battery replacement after six years?
6The car is over three years old, and recently the key isn't working well. Could it be that the battery is dead?
7Does your key run out of battery every two years?
8Is it normal for a Cayenne's battery to drain to the point where it can't be charged after not being used for a month in the third year? After replacing it with a new battery, it drains after about 20 days of not being used. This has happened several times. Is this normal?
9Can a car really drive through floodwaters without stalling? Will it need repairs afterward?
10Does the 2021 stock 5008 need a complete fluid change and battery replacement?
