Did you replace the high-voltage battery? They called me to do a battery check and mentioned a free high-voltage battery pack replacement.
How is the battery warranty? Is it a lifetime free replacement?
Is the battery replacement for this electric vehicle free for life?
Can a used X have its battery replaced for free?
4Should I replace the battery at the 4S shop or do it myself? I'm torn.
5Hey guys, when did you change your car battery?
6How often do you guys replace the battery, and do you stick with the original brand?
7Can I use the air conditioning while charging the AION on high-voltage charging? How can I do it without damaging the battery and the small battery? Thanks!
8Should I choose the 2024 Zeekr 009 with a 400V long-range 140kWh battery or the 800V high-voltage 108kWh battery? Any advice from fellow enthusiasts?
9The battery couldn't start the car after 3.5 years and needed replacement, even though the auto start-stop feature was mostly off. Fellow car enthusiasts, when did you replace your battery for the first time?
10Hey folks, when you're doing maintenance, did they mention buying fuel additives to put into the tank?
